Hard Going into gears when cold
Old Nov 14, 2005 | 09:25 PM
1985f350's Avatar
1985f350
My 85 f350 when first started is almost impossible to get into gear until it has warmed up for a couple of minutes is this normal?
Old Nov 15, 2005 | 05:03 AM
srercrcr's Avatar
srercrcr
I've had my 83 since new. I had a tranny rebuild some years ago. Before the rebuild I don't believe it had much of this problem, but now I have it more. I just live with it, it isn't worth giving my money to someone who claims can fix it, but may or may not fix it. Besides, the truck is 20 years old. Maybe it's a rite of passage for getting to be a survivor.
Old Nov 15, 2005 | 07:50 AM
Holmesuser01's Avatar
Holmesuser01
My '84 with the top-shifter overdrive was always tight when cold. I changed the oil in the tranny and replaced it with synthetic, thinking that this might help. It didn't. I gave up and drove the truck for 300k. It is still going strong with its new owner.
Any chance that someone has changed the oil in the tranny and put something thicker that what Ford called for back in it?
Old Nov 15, 2005 | 10:19 AM
Pkupman82's Avatar
Pkupman82
My 84 F150 had a lot of problems with shifting (NP435) when it was cold too, and even after it was warmed up it still shifted kind of hard. Upon replacing the clutch I discovered the input shaft bearing was shot (also throwout fork), the tranny always had a little growl and whine to it going through the gears. I picked up a rebuild kit from Bronco Graveyard and overhauled it myself, it was pretty easy. I change the oil once a year in my tranny, when I do I usually add a quart of Lucas Oil Stabilizer; this helps a with cold weather use. I would suggest adding a quart or two to your tranny with an oil change. I swear by Lucas and most mechanics I know do also, I run it in all my trucks...engines, trannies, transfer cases, differentials, power steering, everything. Lucas manufactures additives for oil, ATF, power steering fluid, and even fuel injection cleaners. It's really good stuff, it runs around 8 bucks a bottle at Advance Auto Parts...give it a try.
Old Nov 15, 2005 | 03:41 PM
1985f350's Avatar
1985f350
im running straight lucas gear oil in my tansmission
Old Nov 15, 2005 | 06:59 PM
Pkupman82's Avatar
Pkupman82
Hmm must just be the nature of the beast, they all have their own personality. One truck doesn't always drive the same as the next! Hope you can figure something out!
Old Nov 17, 2005 | 08:27 AM
0270's Avatar
0270
When its cold out I end up just double clutching to change gears.... seems to work that way.
Old Nov 20, 2005 | 05:26 PM
nickmobile67's Avatar
nickmobile67
Drain the gear oil and replace with 80w 90. I put 85w 140 in mine and it became hard to shift cold, it was fine before that. I usually let it warm up a little when it's that cold anyway and it's fine.
Old Nov 20, 2005 | 08:58 PM
Boss429F150's Avatar
Boss429F150
do u realize how thick the Lucas gets when it's cold? Get a bottle and leave it outside overnight. In the morning take the cap off and flip it upside down, it gets extremely thick. I run 1 quart lucas in my motor and last winter i went to put sum in after an oil change. When i flipped the bottle to pour it I decided not to put it in, can't be good to have something that was almost solid in there. that bottle had sat in the truck for a day or so. Just a thought, run the 80w90.
fordper4mance
Jan 18, 2012 04:56 AM
emmagator
Sep 8, 2009 09:07 PM
davidsca
Mar 10, 2006 11:52 AM
northlandman
Mar 20, 2005 10:35 AM
jowilker
Mar 27, 2002 12:13 PM
