rust around pistons
Old Mar 13, 2002 | 10:51 AM
boominj's Avatar
boominj
rust around pistons
the other day i pulled the heads off to put a new head gasket on and it started to rain. Well it rained for three days and I had to work everyday for five more days then when i went to check on it this morning the block has light rust around the top of the pistons. How do I get this off safely before I put it back together.
thanks for any help. Oh yeah it's a 77 f-100 with a 302.
Jason Sutton
Old Mar 13, 2002 | 11:41 AM
tetraruby's Avatar
tetraruby
rust around pistons
Scotch brite or maybe some metal polish - just make sure it's clean and free or particulate before buttoning it up.
Old Mar 13, 2002 | 11:46 AM
79f3504x4's Avatar
79f3504x4
rust around pistons
Scotchbrite or coarse shop rag use spirits,ATF,Varsol clean really well.I have even used a vacuum.
Old Mar 15, 2002 | 07:41 AM
STEVE1103's Avatar
STEVE1103
rust around pistons
When you leave it apart always put a light coat of oil all over, I put Marvel mystery in a spray bottle, works great.
Old Mar 16, 2002 | 02:47 AM
Torque1st's Avatar
Torque1st
Posting Legend
Post rust around pistons
I always use white lithium grease around the top of each piston to keep grit from falling down around the piston top. The grease catches the grit and dirt so it can be wiped away at the end of the job.
Clean the piston tops with a wire brush while you are in there. Just keep applying the grease, moving the piston, and wiping away the grit.
over!
Drive 'em forever!
Old Mar 16, 2002 | 03:13 AM
karljay's Avatar
karljay
rust around pistons
