shake rattle and roll
Old Nov 14, 2005 | 07:47 PM
amish hillbilly's Avatar
amish hillbilly
I have a shake when my f150 4x4 is accelerating, loading the drive train in 2w drive. it happens just before the automatic shifts in to last gear or over drive. I can stop the jumping when I let off the gas. There is also a mild whineing noise that can be silenced by also letting off the gas but returns during engine braking.
Old Nov 14, 2005 | 08:08 PM
Beast12's Avatar
Beast12
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Thread moved to 87-96 F-Series trucks forum.
See ya on the boards!
-Matt
Old Nov 14, 2005 | 08:13 PM
clipper1's Avatar
clipper1
Look a the u-joints. Sounds like the back one to me.
If not maybe a tranny mount. Get under ther and grab the end of the tranny, and push up hard. It should only move a very small amount.
Old Nov 14, 2005 | 08:22 PM
amish hillbilly
I have replaced both u joints. But I will check the tranny mount next. Thanks for the input.
Old Nov 18, 2005 | 04:47 PM
amish hillbilly
I have checked the tranny mount, it is ok. While doing that I found that the rear out-put shaft ( slip spline type ) has alot of movement the wrong way. Found a drawing in the Haynes Repair Manual of the tranfercase out-put; it shows a seal and a ball bearing in that area. It also speaks of a (rear extension housing) bushing replacement. I'm hoping that these could be the problem. Going to tear into it this weekend, any advise would be appreciated.
