3 speed to a four speed
I have a 65 ford f 100 that has a 3 speed and I would like to put a four speed in it with a floor shifter. It currently has a 352 engine. I have a four speed tranny but it is a bout 6" shorter then the 3 speed and the bell housing from the 3 speed will not bolt onto the 4 speed.
Any help on how to do this would be appreciated.
Thanks.
Jack
Thanks.
Jack
I had this same problem. I'm putting a 4 speed in my 66.
The 66's 3 speed bellhousing won't work, but there are only 2 styles of bell housing. the earlier type will work with the 4 speed and is a little longer.
the problem you will encounter is that most of the 4 speeds don't have a place to put a rear motor mount, so one will need to be fabricared to mount to the bell housing and the cross member that runs undernieth.
NP435's have an aluminum top cover, t98s, t18s, and t19s have a cast cover and have either their type, or a 13-01 cast on the drivers side
