Codes 305,306
Old Nov 14, 2005 | 06:40 PM
F4fixer's Avatar
F4fixer
Codes 305,306
My sons 2000 ranger running rough around 45 mph. codes 305 and 306 are showing up can anyone tell me what they are and what needs to be replaceed.Thank you in advance.
Old Nov 14, 2005 | 06:58 PM
RangerPilot's Avatar
RangerPilot
I don't see a code 305/306 on my code list.
We need to know engine size and transmission if you can tell us please.
Old Nov 14, 2005 | 07:56 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
P0301 thru P0310 are misfire codes, cylinders 5 & 6 are the area to check.
Old Nov 14, 2005 | 09:39 PM
F4fixer's Avatar
F4fixer
Thanks
Thanks for your help.Can you tell me what i might need to replace.or what is the most common cause for these codes.
Old Nov 14, 2005 | 09:48 PM
AlfredB1979's Avatar
AlfredB1979
Well, since you have the truck up close, you really need to diagnose to avoid tossing money at unneeded parts.
But, off the top of my head, it could be bad plugs, wires, or even rotting coil packs.(Both? Owww.)
Check your plugs and they'd likely give a clue to what's going on inside the combustion chambers.
Old Nov 14, 2005 | 10:03 PM
RangerPilot
And if you replace those go ahead and replace all of them, might as well do the wires as well, keeps everything in good condition.
Old Nov 15, 2005 | 07:53 PM
Ken00's Avatar
Ken00
What engine do you have?
ballbandit
Jul 25, 2011 02:40 PM
HSI111
17
May 12, 2011 11:03 PM
toddwilliams10
May 5, 2010 07:39 PM
toddwilliams10
1997 - 2003 F150
May 5, 2010 03:40 PM
Renagade 306
May 12, 2006 05:46 PM
