electrical nightmare-help
Old Nov 14, 2005 | 05:58 PM
firefighterF250's Avatar
firefighterF250
hello all, i have an 85 F250. It have two electrical problems I'll start with the tail lights. They quit worken also turn signals and brake lights. I was having problems with chraging ran wire from voltage regulator to battery. It charged but blow alot of fuses. I replaced them removed wire back to voltage regulator.
Still cant get any lights in back.them one of the wires from headlight swith got very hot and strated to melt. it runs from swith to fuse box.
I have been reading other post and from what i read Im not grounded right. Have one ground cable from (-)negitive post to moter,. The secoung is charging sytem. I have replaced battery/alternater and voltage regulater.never charges very well and at time the light comes on at idil or slow speeds. Im at my witts end. can anyone help?
Old Nov 14, 2005 | 07:12 PM
subford's Avatar
subford
I take it you ran a wire from the Battery Pos. post to the Reg. "F" terminal.
That will take all regulation out of the system and burn up bulbs and the fuse links from the alternator to the starter sol., maybe the fuse links opened and saved the battery and alternator. Make sure the regulator is grounded and not saying you have ground problem but you can never have it grounded too much, in this case the more grounds the merrier.
You may have all of the bulbs burned out or a bad fuse for these systems.
Old Nov 14, 2005 | 08:01 PM
Franklin2's Avatar
Franklin2
Do you have a testlight or voltmeter, and know how to use it? You will need something like this to figure out the tailights.
One ground from the battery to the engine is not enough. The engine and tranny are mounted in rubber motor mounts. You need small grounds from the engine block to the sheetmetal up front and also the firewall.
Old Nov 15, 2005 | 06:23 PM
firefighterF250
thanks for the help will be worken on it again this weekend will let ya know how it goes
ryank59701
Electrical Systems/Wiring
15
Jun 14, 2019 10:32 PM
brian1985f150
19
Feb 7, 2017 05:52 PM
sjbrink
59
May 20, 2016 02:54 PM
Mad tiki
15
Dec 14, 2015 10:08 AM
ryank59701
Oct 19, 2015 02:04 PM
