What Effects Speedo Readings?
Old Nov 14, 2005 | 02:31 PM
gpriestland's Avatar
gpriestland
Hope someone can help me on my first post!
I recently replaced the Transmission (AOD) on my 1989 E150 Van with a used AOD transmission from another unknown vehicle. (Might have been a Lincoln?).
I have a different problem now - the speedo is about 12-15% out, a bit too much for my liking...
There must be some difference in between the 2 transmissions but there was nothing physically different. Is there any adjustment at the transmission or speedo to correct this problem?
I am assuming that there is a different gear or something in the transmission tail section where the speedo cable plugs in, but I hope not 'cos that sounds like a big job for a small annoyance...
Any help appreciated.
Garry, UK
Old Nov 14, 2005 | 03:07 PM
pfogle's Avatar
pfogle
On the side of the AOD where the speedo cable hooks in look for the retaining bolt. Remove it and slide the adaptor out. There should be a gear on the end of it. Do the same on the old trans, and put the gear from the van in it.
Old Nov 15, 2005 | 01:11 AM
gpriestland
Thanks for the quick reply. Now that sounds like a smaller job! Weather permitting, I will try it this weekend.
Old Nov 15, 2005 | 01:10 PM
gpriestland
Actually, had a look at the old transmission in the garage. Maybe I am missing something, but the old box did not have a speedo cable in it and so there is nothing in the hole where the speedo cable should go.
Also I have only ever had 1 speedo cable - the one originally on the van.
I am guessing this means I have got to get a different gear for the end of the speedo cable? If so - does anyone have a part number or description - that sort of thing might be hard to source in the UK.
Garry, UK
