shift knob
Old Nov 14, 2005 | 11:37 AM
boilerperson's Avatar
boilerperson
shift ****
The shift **** on my 95 F-150 won't stay on. It ends out in my hand. I have been putting paper in it to shim it up. Well, I guess I did it one too many times. The thing split in two.
Two questions, one is do you just tap a new on on? On other stick vehicles I had the shift ***** screw on. This one's splined. Also because it is splined, do I have to get a factory replacement or will an after market one work. Any recomendations on where to get one?
Thanks !!!
Old Nov 14, 2005 | 11:53 AM
phoneman91's Avatar
phoneman91
Ford still sells shift ***** and they just press on. Or you can buy aftermarket.
Ford's new shift ***** will not be the same style as the original.--but will work fine.
National Parts Depot sells them.
Old Nov 14, 2005 | 12:51 PM
whiteyfordzx5's Avatar
whiteyfordzx5
just get a new stock one. aftermarket don't stay on worth crap. yours is just worn out from coming off one too many times.
Mike
Old Nov 14, 2005 | 01:35 PM
Roushians's Avatar
Roushians
I went aftermarket, you know those cheap dark chrome skull shift *****.
If you properly shim up the stick so that the **** just fits onto it snug, then use thread-lock the little screws, it'll never come off (by accident).
Mine came off a few times before I properly did it up.
Old Nov 29, 2005 | 06:59 PM
canadian 94 ford's Avatar
canadian 94 ford
I bought an aftermarket **** at Walmart and you shove it on and tighten 3 set screws and then you slide a collar up over the screws. Ithas been on for 3 years and has not come off.
