elctical ?
Old Nov 14, 2005 | 10:35 AM
pacochico's Avatar
pacochico
elctical ?
I have 77 F-100 my truck have on the cluster the seat belt ligth I wonder how this light work my seat belt alarm work but what about the light how does work.
any tips of how can in trobleshote the horn .
Old Nov 14, 2005 | 10:45 AM
73Custom's Avatar
73Custom
Are you saying the seatbelt buzzer works but the light does not come on? If so, start by pulling out the cluster and check the bulb and connections for this light.
The horn works by grounding through the steering column. Check all the fuses. Do you hear a clicking under the hood when you push the horn button? Us a wire and jump from the + battery terminal to the terminal on the horn - it should blow if it works. Let us know what you find, then we'll go farther.
Marty
Old Nov 14, 2005 | 12:54 PM
pacochico's Avatar
pacochico
yes the buzzer works I check bulb and is good and the conctions seem to be right whatelse can I check.
As far the horn I will look in, will see
