I was changing the oil in my '05 Buick this weekend. I looked in the manual to see if I could use some of my stockpile of SL oil, or if I had to crack into my stockpile of SM oil (I was sure that I did not have to crack open my stockpile of CH-4 oil )
Anyway, GM does not spec out SH, SL, SM, etc. Instead, they tell you to use an oil that meets the GM spec (GM3094 or something like that). I checked the book on my '04 GTO, same thing (except it was written on the opposite side of the page ).
The SM 5w-30 oil (Exxon) had that spec on the bottle, but the 10w-30 (Exxon) SL oil did not.
Funny. The industry argued for years to get the API SM rating issued, now it looks like they still don't agree.
That spec requires 5W-30, so even SM 10W-30 would not qualify.
Despite every effort to include all major manufacturers in API and ACEA specs, more and more wont just go with it. BMW Longlife, VW, GM and Ford oil specs, Dexron VI, Mercon V and +4 ATF's and the list goes on. Now we even need a different coolant for each make.
Gee, that's funny. The book says "Make sure that you use oil meeting GM3094 or else blankety, blankety, blank."
The book also says 5w-30 is preferred, but 10w-30 is acceptable.
H'mmmm. I wonder which one is right.
No real problem, short of Emu oil, I am pretty well covered.
You are fine with SM oil of any grade approved in manual. I think the lack of SM spec in manual is a vain attempt by Gm to get you to bring vehicle to dealer for regular servicing. By law they cannot make it it use only a GM spec engine oil and mandate dealer changes on oil.
The GM spec 6094, which is probably the one you are referring to, has to do with the cold flow properties of the oil. I don't have the exact spec in front of me and I wouldn't want to give you wrong info but I believe it has to have a cold pour point of - 30F. GM engines suffer from not so hot engineering in regards to the lube system. The oil MUST flow at cold temps or damage at the mains will happen, in particular, the front main. This is the reason the Corvette requires a PAO synthetic.
My unerstanding is that GM went to 5w30 because of improved cam lobe oiling in cold temps and the reason that they went syn with vette is because engine compartment is so tight that engine oil temps can exceed 300 degrees at times in bearing areas.
Could be. I was going from memory.
Cold flow is not much of an issue in Dallas/Fort Worth. I have plenty of both oils, and plenty of cars that can take the "cheaper" SL 10w-30. My '50 Chrysler and '54 Dodge eat it up. So do my 60s era Ford Falcons.
I lived in Teaxs for a bit in mid 70's and that was the only place I have ever been that you could buy straight 60 and 70 weight engine oil off the shelf at the time.
Only reason Corvette is speced for PAO is that the sump temperature will go above 305F in hard roadracing conditions, and not installing an oil cooler for the 99.9% of Vettes that will never get used to this potential was a no brainer.
The above is straight from the GM engine engineer that helped design the system.
PS - back to the original question, the GM spec translates to a 5W30 SM GF4 spec oil. Most 5W30 on the shelf are GF4 now.
