early 99 turbo options
Old Nov 13, 2005 | 08:50 PM
bigcountry560's Avatar
bigcountry560
Hello, I have a early 99 F350. Just curious what my options are to upgrade the turbo. I've pretty much decided that there aren't any options without converting to the setup on the late 99s. I've seen one kit on dieselsite.com for over $900. I was just wondering if there were any other options or kits or someone who has done this before. Here's what I'm workin with:
early 99 F350 7.3 (mean green)
6 spd
Tymar intake
5 inch exhaust
Diablosport Predator
3 guage pillar (boost, pyro, oil press)
Any suggestions would be appreciated,
Mike
Old Nov 13, 2005 | 08:55 PM
BadFord99's Avatar
BadFord99
I have an early 99 myself, and am going to upgrade my turbo to a Holset H2E. They make a kit for the early 99 with optional 3" intake plenums. It's kinda spendy, but it is a pretty sweet setup, and can handle a great deal of hp.
Old Nov 14, 2005 | 02:51 PM
1984_355w's Avatar
1984_355w
Where can you view the holset? We also have an early '99 just like yours and we are putting a lot of oil through it. Time for an upgrade!
Old Nov 14, 2005 | 05:49 PM
BadFord99's Avatar
BadFord99
Check your email, I sent you a link to a site where you can read about and purchase the H2E.
Old Nov 14, 2005 | 08:03 PM
edub32's Avatar
edub32
I've been looking at the van turbo swap recently. You take a turbo off of a 99-03 Powerstroke van, upgrade it, and replace it with the turbo in your truck. The Van turbo is better than our stock turbo because it has a bigger Exhaust Housing (1.15 AR). It also doesn't come with a wastegate which is also nice. The upgrades that are usually done are adding the ATS Ported Shroud Compressor Housing and you'll need to get the Van Turbo Flange Downpipe adapter. You can find those parts at Diesel Innovations under Products, Ford, 7.3 Liter, Induction.
This turbo is pretty inexpensive (compared to BB's and the H2e) and it can support lots of power (around 400 HP). Good Luck
Old Nov 14, 2005 | 08:10 PM
edub32's Avatar
edub32
Wow, I saw you had an EARLY 99 so I guess the van turbo swap doesn't help
Old Nov 15, 2005 | 10:17 AM
Fat Diesel's Avatar
Fat Diesel
Actually the van turbo swap isn't too bad, just find someone who has gone to the Hypermax and get thier old stuff to plumb in your van turbo. From what I understand it doesn't have an exhaust back pressure valve either.
