Transmission fluid change on 96 w/153k
I have 153k on my 96 bronco, the fluid is starting to look a little dirty. The truck runs great, I would just like to do some preventive maintenance. What is the safest way to change the fluid and filter and what is the best product to use? Any suggestions,
Thanks,
Armand
Thanks,
Armand
Safest is by using a pump throgh dipstick tube (jcwhitney sells one, I know that for sure) to suck out as much as possible, then remove the pan, drain the torque converter, and replace the filter. (which is more like a screen) If you don't have pump, you just have to be a bit more careful when removing the pan and draining the tha ATF.
The E4OD need for Dexron/Mercon, no Mercon V, and dual rated fluids (Mercon/Mercon V) aren't exactly ideal either.
