Looking for opinions on whether an aftermarket coil--the 40k blaster type is worth it for my 302 79. I suspect that the stock coil is adequate for just banging around but always looking for an edge mileage and drivability wise
Blaine, the Blaster is a good upgrade coil. The stock DuraSpark coil puts out about 30Kv, so you can compare with that. After the new coil, I would go with some low resistance plug wires. With the new coil and wires, you can open up the plug gaps to about .052-.055".
Thanks. I have the new wires, brass type dist cap and a new module so the coil would be the next thing. Who makes the Blaster? And thanks for the gap trick.
[updated:LAST EDITED ON 20-Mar-02 AT 11:47 AM (EST)]Blaine, MSD makes the Blaster 2 coil. Jacobs, Accel, and Mallory are other brand names. Pick the brand that you like the best, they are all good. My experience has been with Mallory; no problems at all.
Actually, the reason to use a higher voltage coil is so that you can widen the plug gaps. The extra voltage is needed to jump the wider gap; and the wider gap gives a better ignition to the fuel charge. If you put on an aftermarket coil without widening the plug gaps, you don't get the full benefit of the new coil.
I like the ACCEL electronic coil. I'm using one with the 300+ system. I haven't had much luck with distributors. Next one I buy will be roller bearing H.E.I. with vacuum no matter the cost.
Make sure you get a "steet" coil rated for 100% duty cycle. A racing coil wont last long on the street.
