Heater blower motor
Old Mar 19, 2002 | 04:48 PM
EquineGuy's Avatar
EquineGuy
Heater blower motor
Question:
My blower heater motor stopped working one day just before inspection. I was getting 12v at the motor, the ground is good.
I also did a direct hook up from a separate power source. The motor still did not turn. The fan moves freely by hand.
2 days later -
I go to the junk yard and pick out a new motor, and a heater coil ( in case my goes bad )... I get home and whaddaya know!! My still installed motor works just fine.
Now... does this motor contain a thermostat that caused this prob? I figure its somewhere from where the leads go into the motor.
Old Mar 19, 2002 | 05:42 PM
lshort's Avatar
lshort
Heater blower motor
[updated:LAST EDITED ON 19-Mar-02 AT 06:44 PM (EST)]must be a gremlin
Larry
Old Mar 19, 2002 | 09:20 PM
85351ho's Avatar
85351ho
Heater blower motor
check your muffler bearing for water contamination, also check your washer fluid
(sorry i couldnt resist)
Old Mar 20, 2002 | 04:53 AM
EquineGuy's Avatar
EquineGuy
Heater blower motor
lol... haa haa.. I was actually being serious. Ticked me off that it stopped working for inspection.... then worked a day later.
But, I did happen to tighten the wobbly shaft and refilled my back-up light fluid.
Old Mar 20, 2002 | 11:36 AM
beartracks's Avatar
beartracks
Heater blower motor
If you do replace the motor and coil don't use used parts. It's way too much trouble to have to do twice. Especially if you have AC.
Bear Tracks
Old Mar 20, 2002 | 03:17 PM
ford_nut's Avatar
ford_nut
Heater blower motor
