1978 - 1996 Big Bronco
ball kit for the universal joint
Old Nov 13, 2005 | 01:22 PM
poffutt's Avatar
poffutt
89 351
I am in the middle of changing my two u-joints that sit right behind the t-case attached to the drive shaft going to the rear end. After removing the u-joints I noticed that their is this spring in the middle of the yoke closes to the t-case and it goes inside of this ball that has the pin bearings just like the bearings on the u-joints. These pins are all worn out and chewed up. Is their a kit for this or do I have to go to the dealership and buy the whole yoke. Please help I am with out a vehical.
Old Nov 13, 2005 | 04:19 PM
muckypaws's Avatar
muckypaws
bronco grave yard sell them. The Joint you mention is a double cardan joint.
for example:
http://broncograveyard.com/bronco/i-...g__1990-96.htm
but check the year! this is just the first one I came across.
Old Nov 14, 2005 | 09:07 AM
InkDawg's Avatar
InkDawg
Originally Posted by poffutt
89 351
Napa has the part your after...I think it was like 30 bucks but its been a few years since I replaced it...
1984F2506.9
Dec 4, 2014 11:32 PM
FourXFord2
Jun 25, 2014 07:50 PM
ErrorS
May 4, 2008 01:30 PM
udontknowme
Jan 24, 2008 04:08 PM
