Towing upgrade?
Old Nov 13, 2005 | 01:52 AM
dorsetmerv's Avatar
dorsetmerv
Towing upgrade?
I have a 1988 F250 stock xlt lariat with axel code 39. I intend to do a couple of towing trips a year of about 700 miles return taking me over the casscades towing a fairly light load under 4000 lbs.. Do i need any towing upgrade or is what i have ok?
Thanks for your input guys.
merv.
Old Nov 13, 2005 | 06:27 AM
deanj's Avatar
deanj
You did not say if it was auto trans. If it is auto I would put an auxilary trans cooler (with fan). A trans temp guage and a pyro - some of the hills are a bit steep. Other than going to larger exhaust, and removing the "soup bowl" in the intake (plenty of threads on this) their is not much I would do.
Old Nov 13, 2005 | 06:34 AM
shorthair's Avatar
shorthair
i have a 90 n/a 4x4 3.55 zf5 and tow 8000+ over the cascades several times a year im not the fastest but not as slow as i thought i would be.
Old Nov 13, 2005 | 11:20 AM
9inchaxle's Avatar
9inchaxle
I have a Banks Turbo & Gear Vendor overdrive on a 1984 6.9. This setup is made for a 5th wheel ~4500 lbs. It loves to pull. I love to pass small cars on major hills.
Old Nov 13, 2005 | 11:27 AM
dorsetmerv's Avatar
dorsetmerv
deanj, how much money are we talking for these upgrades and thanks all you guys foryour input.
Old Nov 14, 2005 | 06:26 PM
deanj's Avatar
deanj
If it's an auto, you can get a water temp guage from your local parts place - get on that reads to 280, mount it in the out let tube from the trans. The trans cooler and fan can run around 180 (mine is mounted in my bumper thats why the fan) can turn it on when it gets to 180 or so. Your local muffler shop can do the exhaust, muffler or not is up to you, but get a straight thru (see thru) run 2 1/2 min with dualls. The soup bowl is just a cut out job (search for threads on how to do). Hope this helps.
