Heater Ideas
Old Nov 12, 2005 | 11:00 PM
1954blueoval's Avatar
1954blueoval
Heater Ideas
What are people using for a heater in their truck? I have a small Vintage Air unit that I was planning on using, but if there is anything that will look somewhat stock I would rather have that.
Old Nov 13, 2005 | 07:27 AM
49willard's Avatar
49willard
If interested I have an original heater that I believe is correct for your truck. I have had it stored for years. Contact me back channel if interested. What are you looking for?
Old Nov 13, 2005 | 07:36 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I'm using a small 12V box heater made by the Hupp company in my 48. I've had it for years so I don't remember where I got it. It has a door in the front which can be opened for more heat and holes on the sides where defroster duct hoses can be attached. You can buy a small box heater from places like JC Whitney and others for around 75 bucks. These are the same heaters you used to buy from them for $29.95...inflation is a bitc....
Vern
Old Nov 13, 2005 | 10:39 AM
ferguson777's Avatar
ferguson777
I too would be very interested in knowing what most people are using for heaters as well.
Are most people using their stock/original heater and finding them adequate? (Particularly people in the northern states/Cda. Knowing somebody in Calif is using their stock heater doesn't really seem to be that resounding an endorsement (if you know what i mean).....
Old Nov 13, 2005 | 12:37 PM
1949f1's Avatar
1949f1
my truck came factory without a heater. the factory knockouts have never been knocked out. the man i bought it from had one from a older gmc put in it. they trilled out there own holes. it still works and say's gmc on the front.panel that has doors that open for heat with a motor for heat and one for defrost.he had the truck for 35 years.and never changed the plug wires. still run's great.but i am going to change them during restore.
Old Nov 13, 2005 | 02:01 PM
Mats Nilsson's Avatar
Mats Nilsson
Hi!
I live in Sweden and use my truck all the year around. Sometimes it´s very cold and I use the original fresh air heater. It´s very good and the temerature in the cab is fantastic for an old truck like this. I was thinking of using an extra ford recirc. heater and place it under the seat but it was not necessary. I do use some extra insulation in the roof and under the carpet(about ½ inch thick) and have door panels which makes it warmer in the cab.
Good luck!!!
Mats Nilsson, Kiruna Sweden
Old Nov 13, 2005 | 06:19 PM
abe's Avatar
abe
Fergie,
still using the original heater. I took it apart, cleaned it up, had a electronics teacher at my school look at teh blower motor. I painted it, put it back together and it is great. Two winters ago it was so hot I had to turn it off or open windows, then I replaced my thermostat which was not working and now not as hot but still good enough.
abe
Old Nov 13, 2005 | 06:20 PM
abe's Avatar
abe
By the way,
I have the recirculating heater,
abe
Old Nov 14, 2005 | 12:09 PM
Deebo54's Avatar
Deebo54
I have a fresh air heater, just put in a new motor (12v), but now my heater core is leaking. I am sure it can be repaired, but has anyone found a reasonably priced replacement. My measurements (for the heater core) are 2 1/2 x 9 x 6 1/2. I looked at similar years both cars and trucks and the closest I have seen is a 65 mustang, slightly smaller with shorter inlet/outlets.
It's good to hear that it works well, it gets cold in Minot ND!
Old Nov 14, 2005 | 12:34 PM
GreatNorthWoods
Take your core to a radiator shop where they can match it up or make you a new one.
Vern
Old Nov 14, 2005 | 01:48 PM
Fifty F3's Avatar
Fifty F3
Mine's a fresh air heater, the name of which, I'm sure, was on the missing plate over the end of the blower motor shaft. It's identical to the ones discused here a few months ago, something Aire, I think. Anyway, it uses just the factory knockouts and works well with no interference from me.
Dave
Old Nov 14, 2005 | 02:25 PM
Brian_B's Avatar
Brian_B
No clue. I have not picked up the truck yet, but here is what is in it. They guy says it works, but how well? Guess I will find out soon enough.
Anyone know what it is and if its factory?
Old Nov 14, 2005 | 08:30 PM
55FordLover's Avatar
55FordLover
Have the original and just finished cleaning and painting mines...have to knock-out the holes and run the lines....hopefully I won't need it in HELLPASO, TX this winter...usually around the 45-60s during the winter months.... :-)
James
Old Nov 14, 2005 | 09:41 PM
HT32BSX115's Avatar
HT32BSX115
I have an original fresh air heater for mine.
I got it from a nieghbors parts truck and completely sand blasted it inside and out . I then painted it inside and out using crinkle paint on the outside. The motor was the wrong unit for this heater. It was a 12v unit but it rotated the wrong way! I bought a replacement (permanent magnet) motor from National Auto Parts for about $50. I also had to resolder the core to fix a leak. (It holds 20 PSI now).
After sandblasting and painting it now looks brand new. I'm going to use it until I do the complete restoration...then I'm going to replace it with an Antique/Vintage Air etc system.
If you can find one of these fresh air heaters I would go that way. I really like the fresh air heater over the recirculating model.
Cheers,
Rick
Old Nov 14, 2005 | 09:47 PM
abe's Avatar
abe
Brian, you have the recirulating heater and yes it is original. They paint up real nice. I think they look better than the Fresh Air heater which were in the Deluxe cabs or bouhgt as an option.
Look at my gallery to see mine after I painted it.
abe
