alternator question
Old Nov 12, 2005 | 10:51 PM
fordflaresides's Avatar
fordflaresides
alternator question
I got a new alternator for my 1973 f100 w/ Inline 6. I replaced the 38Amp with a 61Amp. It has 5 terminals. Labeled batt., grnd., fld. and two unlabled terminals, one with a plastic insulator. I know batt. connects to the wire going to my relay, I know grnd. goes to my voltage regulator but then I have a metal bracket coming out of the wiring harness that conncected to a terminal on the old alternator, does anybody know which terminal this goes to on the new alternator and what it's for?
Old Nov 12, 2005 | 11:36 PM
Mil1ion's Avatar
Mil1ion
The last 2 !
One is a stud & the other is for the stator.
Old Nov 13, 2005 | 12:00 AM
ford390gashog's Avatar
ford390gashog
the metal bracket just screws onto a stud
Old Nov 13, 2005 | 12:15 AM
fordflaresides
What would happen if I accidently hook the bracket to the stator instead of the stud?
I don't have an electric choke. It appears to only go on one way just want to make sure there is no way I can screw up my electrical system.
Old Nov 13, 2005 | 09:49 AM
Mil1ion's Avatar
Mil1ion
Well since the bracket isn't an electrical device .........zap !!!! once the engine starts !
Old Nov 13, 2005 | 09:36 PM
fordflaresides
Zap!? As in it will just make spark, or will it cause a voltage spike or something?
Old Nov 13, 2005 | 10:09 PM
ford390gashog
how could you possibly install it on the stator?????????????? it is marked stator .
Old Nov 14, 2005 | 02:59 PM
fordflaresides
My alt. only has batt., grnd., and fld. markings the stator is not marked so I not 100% sure which is the stator and which is the stud.
Old Nov 14, 2005 | 04:13 PM
satx77stepside's Avatar
satx77stepside
Not sure if this is the one you are talking about, but if it helps...
Old Nov 14, 2005 | 04:18 PM
satx77stepside
ok, i've tried posting an image 4 times, keep getting an error saying I'm moderated or something...... let's see if I can just post regular text.
Old Nov 14, 2005 | 06:38 PM
User 71024's Avatar
User 71024
the stator wire should have a plastic insulator, the stud is just a ground.
Old Nov 14, 2005 | 10:40 PM
fordflaresides
Thanks Eric., The one I thought was the stator does have a plastic insulator.
Old Nov 15, 2005 | 01:01 PM
Pocca's Avatar
Pocca
I'm taking in all this great electrical talk, and then I see this kid peeing on a bow tie. Where's the love, people. HA!
