General Automotive Discussion
vin number
Old Nov 12, 2005 | 08:59 PM
straitsix373's Avatar
straitsix373
vin number
When buying a truck online the seller is sometimes to lazy to tell you the axle ratio.. Is there a way to get that info from the vin #.. Trucks in the mid 90's
Old Nov 12, 2005 | 09:28 PM
sierraben's Avatar
sierraben
No.
Unless you know of a dealer who has access to the data base that has the build sheet on that vehicle (at least for GM; don't know about Ford, though)
Probably much easier to have the party give you codes off of the TRUCK SAFETY COMPLIANCE CERTIFICATION LABEL.
Those codes will tell you what the vehicle has.
Pretty sure.
Old Nov 12, 2005 | 09:58 PM
straitsix373
I think there is a way to decode the vin... I know the 8th number is the motor size and the 10th is the year... but that's all i know
Old Nov 12, 2005 | 10:09 PM
sierraben's Avatar
sierraben
True. But not the axle ratio.
straitsix373, You're absolutley correct. The tenth digit code was the year, as was the eight digit for the engine code, starting from (1981; at least on a GM).
I think the first ten characters on a V.I.N. told quite a bit.
Old Nov 12, 2005 | 10:18 PM
RangerPilot's Avatar
RangerPilot
Here you go, a free web decoder of VINs:
http://www.analogx.com/contents/vinview.htm
EDIT: wasn't as helpful as I was hoping...
Ran my mom's Silverado, it knew it was a Chevrolet, said it was made in Canada (I guess it could have been, though we live in Texas), got the year 2000 right, said it was made at assembly plant 1, didn't know it was a Silverado, didn't know engine size.
Oh well better than nothing I guess...
Old Nov 12, 2005 | 10:28 PM
sierraben's Avatar
sierraben
I also ran my VIN.
Oh well.
Better than nothing.
Old Nov 12, 2005 | 10:44 PM
straitsix373
might be gittin there... digits 4-8 are the model/specific. And we know that the 8th is the motor.. that leaves 4 digits that might tell me a axle ratio.. 4-7 my truck has 3.55 gears and digits 4-7 are EF14
Old Nov 12, 2005 | 10:46 PM
straitsix373
IF someone else has a truck with 3.55 gears we might could fig it out
Old Nov 13, 2005 | 12:45 AM
polarbear's Avatar
polarbear
It's not in the VIN codes. On GM, there's a separate tag that in the glovebox or under the hood that lists the 3-digit RPO's of everything on the vehicle. You have to know your codes (or someone that does), but its all there. Axle codes always start with a "G**." A G80 is a locker, and an alpha-numeric code is the axle ratio.
That's all waaay too easy for Ford. On the later model ones, you can run an OASIS to get the equipment, or look for a tag on the rear axle.
Old Nov 13, 2005 | 01:12 AM
straitsix373
well that's the problem.. I'm buying a used truck online.. it could be 200 miles away, and it's hard to get some of sellers to check the tag on the rear or sticker on the door.. All I can see is a vin #... The serial number is in the vin.. I would think some computer program could tell ya how it was built.. They have websites that tell you if the truck ever hit a deer or if you have ever been pulled over.. If the vin can tell you that I'm sure it could tell you what major drive parts are in it.
Old Nov 13, 2005 | 01:34 AM
polarbear's Avatar
polarbear
Nope- you can track where it's been and what it's done by the VIN, but on a Ford you have to literally pull the case off of the rear diff and count teeth. With GM, on the other hand, I've been looking at equipment stickers for almost three decades.
I've asked it before- who the heck does Ford use for IT people?
Old Nov 13, 2005 | 01:54 AM
sierraben's Avatar
sierraben
polarbear, you brought back some ole memories.
I used to work for a GM dealer a long time ago.
I know about that little white sticker (RPO).
Sometimes under the deck lid, sometimes on the spare tire cover, sometimes in the glovebox, etc.....
"B" were body molding options
"J" were brake options
"M" were trans codes
Etc.........
We did have a way to punch in the VIN and get all of this info, but I'm not sure if this was (in house) for the vehicles that we sold or all GM.
Been a while.
Old Nov 13, 2005 | 02:30 AM
polarbear's Avatar
polarbear
I can punch in a GM VIN and get, instantly:
vehicle invoice
sales history
service history
incentive payment history
build sheet
You guys used the old GM warranty history program, now known as VISS. The old system (two decades old) is comparable to what Ford uses today. When i order a new Ford, concepts is exactly like GM's original online legacy program they trotted out in the early 80's. For a computer nerd, it's literally like stepping back in time a couple of decades. Unbelievable.
Old Nov 13, 2005 | 09:40 AM
rebocardo's Avatar
rebocardo
If they can not do that, how likely is it that they took good care of the vehicle, actually own it, are honest in the description, or will help if there is a problem after you bid?
On E-Bay I wanted to bid on a 1980 Ford Econoline 4x4 in NJ. The seller could not bother posting the VIN #, the vehicle went unsold. I bought another vehicle from a buyer that provided all the info and even drove the vehicle to my house for me to check out. I bought his van without even dickering about price because I liked it.
If someone can not bother to give you the info you need, at least from a door, then do not bother to buy it, imo. Though I can see someone not wanted to crawl under for an axle tag.
