clutch release bar
Old Mar 21, 2002 | 03:27 PM
Jermafenser's Avatar
Jermafenser
clutch release bar
Old Mar 23, 2002 | 08:29 PM
indy10's Avatar
indy10
clutch release bar
Does anyone know if a clutch release bar (equalizer bar?) off a v8 engine will fit on a 300-6? I know the sixes have a pivot ball that screws into the engine, but I think the 8's have a ball off of a plate. It looks like it will work, but just wanted some advice.
TONY
Old Mar 23, 2002 | 09:30 PM
Art's Avatar
Art
clutch release bar
I know the bellcranks are interchangeable between smallblock (302) and I-6, and that the bellhousing is the same for the two. I have done it on 67-72 and 73-79 trucks. On smallblocks, the engine side pivot screws into the block on earlier engines, but starting around 1977 they used a pivot bracket attached with two of the bellhousing bolts.
I believe that FE (360,390) and 429/460 use the same bellcrank too, but am not 100% sure.
Art
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3068&.jpg
