Smooth my ride
Old Nov 12, 2005 | 04:01 PM
jdbanks's Avatar
jdbanks
Smooth my ride
I'm looking for options to smooth out the ride in my 67 f100 SWB. I'm wondering how much difference some high-grade shocks can make? I just recently got the truck so I'm not sure how old the current shocks are. The ride seems pretty stiff.
Also, the rear has traction bars and I'm wondering if that would have any affect on the cushion of the ride?
Thanks.
Old Nov 13, 2005 | 01:29 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
First off the swb trucks don't ride as smooth as lwb trucks, something you can't change. With a fe and auto the stock front springs should provide a soft ride with all that iron unless the suspension and shocks are binding up. On the rear you can make a softer ride with the same spring pack if you disassemble and polish the contact area between leafs with 120 grit flap wheel. Use Dow Corning's 721 dry film moly spray them reassemble. This would be a good time also to replace spring eye ends with poly bushings. I have a 3/4 that was a back breaker until I rebuilt the rear leafs, 6 years later and still a soft ride without removing any leafs.
.....=o&o>.....
Old Nov 13, 2005 | 06:55 AM
jowilker's Avatar
jowilker
JD, You are riding in a truck, it aint gonna ride like a car. Back when they were built ride was way down on the list.
Pickups were like second class, unlike the tricked out units sold today. My father wouldn't drive his truck to church unless there was a work day there and it was needed.
John
Old Nov 13, 2005 | 01:15 PM
jdbanks's Avatar
jdbanks
Yes John, I know I'm riding in a truck and I've ridden in them forever. This truck, whether it be my imagination or not, seems rougher than others.
At any rate, if people can hack and saw and lower and jack-up and chop top and everything else they do to trucks, I don't think it's too much to ask if anyone has a suggestion for making it a little smoother. I didn't ask for the ride of a sports car or something. My truck is a daily driver and I'd take it anywhere I felt like.
I respect your input John and your knowledge that you've given over the years. Do you have any helpful suggestions. Something other than telling me I shouldn't do what I wish with my truck?
Thanks for your input "Beemer Nut", I'll look in to that. Has anyone tried the high grade shocks? Worth the investment?
Old Nov 13, 2005 | 08:06 PM
"Beemer Nut"
jdbanks....I may be old school in thinking but the best shocks that i've found that last with heavy front end Fords is Monroe Gas Magnum 60's front and rear (over 800K miles with them). Only when it gets below 40 degrees F will they act stiff for a few miles until the oil inside warms up. I would bet 90% of your harsh ride is from the rear springs. As far as wasting money on "high end" shocks I was told I "must run" Biltsteins on my 95 Rover Discovery, what a piece of crap and money waste they were. JMO.
.....=o&o>.....
Old Nov 13, 2005 | 10:32 PM
crewzmaster's Avatar
crewzmaster
Hey JD, I know these trucks can ride smooth. According to Ford's original sales pitch "works like a truck, rides like a car", they knew it too. My first 67 F100 had the best ride of almost any vehicle I had ridden in, ranging from Caddilacs to Volkswagens. I had not heard how to rebuild leaf springs until I read Beemer Nuts' reply. My 3/4 ton crew also rides rough, so I will be rebuilding the rear leafs to see if that helps. Thanks Beemer. I would be interested in your results JD, if you try this.
Old Nov 14, 2005 | 04:35 AM
jowilker's Avatar
jowilker
JD, It was more tounge in cheek. Your rear spring rate will have more effect on the ride and changing shocks. Shocks will dampen the ride that the heavy springs are putting in. That is why 3/4 & 1 ton trucks ride stiffer.
Forgive me???
John
Old Nov 14, 2005 | 07:08 AM
jdbanks's Avatar
jdbanks
Forgive me???
John
Oh John ...how could I not?
Thanks for all the advice guys. I'll let you know how things turn out.
I'm still wondering if those traction/ladder bars have any affect on the ride, if anyone has any knowledge, please share. Thanks.
Old Nov 14, 2005 | 12:13 PM
kwanderi's Avatar
kwanderi
New shocks made a world of difference in my 4x4 swb F100. I would actuall hit my head on the roof before and no more that a bounce after.
Old Nov 14, 2005 | 01:55 PM
qman's Avatar
qman
Here's how a suspension works. Springs provide the cushion for your vehicle to bounce. Shocks stop the bouncing of the springs. The stiffness of the ride is in the springs, not the shocks. Now if your truck bounces you all over the place when you hit bumps then new shocks will cure that. But they won't get rid of stiffness. F100 trucks come with the smoothest set of springs you can get on these trucks.
Old Nov 15, 2005 | 10:09 AM
ford fisherman's Avatar
ford fisherman
My 68 f100 L.B. has a very smooth ride compared to many trucks I have been in. It was pretty smooth to begin with but was even better when I installed passanger car touring steal belted radial tires and got rid of the truck tires. This is a daily driver and I am getting about 4.5 yrs out of a set so far. I feel it was one of the better investments I have made on the truck.
Old Nov 15, 2005 | 10:15 AM
qman's Avatar
qman
I agree with fishman, my 72 F100 lb is also a very smooth ride. And I forgot, good tires do make a difference. So do new tires. Old worn tires make for a rougher ride. My 92 4x4 with a lift is stiffer than heck. I feel every bump in that sucker.
Old Nov 15, 2005 | 03:46 PM
ramtoo's Avatar
ramtoo
Put about 1000LBS in the bed of the truck and see how you like the ride!
