Sponsored by: Kumho
Front to Rear Brakeing Problem
Old Nov 12, 2005 | 09:05 AM
ford351c's Avatar
ford351c
I have a 1990 F-150 that I dont drive very often. ABout every two or three weeks. The last time I went to use it. The rear brake lines were rusted out and the pedal went to the floor. Before this it was working just fine. I repalced the brake lines and bleed them. Before I start the truck the pedal is firm. When I start it up it goes near the floor. When I drive it the pedal is soft and the rear brakes will grab and lockup with them doing most of the stopping power. I have bleed the front brakes endlessly and there is no air in the lines. I have bleed the master cylinder and the antilock module. No air is coming out anywhere. Any ideas what might be causing this???
Old Nov 12, 2005 | 04:43 PM
peppermrj's Avatar
peppermrj
Sounds like you still have air in the rears. Did you check the rear wheel cylinders for leaks?
Check to be sure and then try a gravity bleed and see if you get a firmer pedal.
