ford 391 rods
Old Nov 15, 2005 | 12:54 PM
  #31
ford390gashog's Avatar
ford390gashog
Originally Posted by rusty70f100
Those are long rods. Just for kicks, measure the bore diameter of that block. I kind of suspect something here...
ok i will go measure it. it should be 4.05 right? are you suspecting its a 330?
Old Nov 15, 2005 | 02:19 PM
  #32
rusty70f100's Avatar
rusty70f100
Yes, I'm suspecting it's a 330. They were the ones that got the 2TA cranks, and long rods.
Old Nov 15, 2005 | 02:26 PM
  #33
ford390gashog
but i thought th 2ta crank was a 360 crank? what size bore would the 330 have? same as the 352?
Old Nov 15, 2005 | 02:33 PM
  #34
rusty70f100
330's have the smallest bore of any FE or FT, at 3.875".
My book shows the 2TA crank used on 360's and 330's. It does NOT show the 2TA crank used on 361's. It shows the D3TE-1 block used on the 330, 360, 390, 361, and 391. I'd guess the bored it differently for the 330. My book also shows the C7TE-A long rod used exclusively on 330's.
Now this book has been known to have omissions before, so that's why I ask about the bore. That will end all doubt.
Old Nov 15, 2005 | 02:55 PM
  #35
cbfomoco's Avatar
cbfomoco
Could you tell me what book you are getting all this info from?? thanks
Old Nov 15, 2005 | 02:56 PM
  #36
ford390gashog
ok well it measure 3.9 or very close to that. so looks like i need to bore it.
Old Nov 15, 2005 | 02:57 PM
  #37
rusty70f100
"How to Rebuild Big-Block Ford Engines" by Steve Christ. ISBN # 0-89586-070-8
Edit: Yep, I'd be surprised if it didn't take a 428 bore. But you wont need to go that far. I'd go 4.050" and be done with it. Not sure what you're going to do with the crank and rods.
Old Nov 15, 2005 | 03:01 PM
  #38
ford390gashog
was the 330 a very common engine? i think i will take it to 4.05 and leave it there.
Old Nov 15, 2005 | 03:03 PM
  #39
rusty70f100
The 330 was a common engine. In big trucks, u-hauls, etc and so on.
But hey, look on the bright side. Now you have a super-reinforced block, and a giant oil pan!
Old Nov 15, 2005 | 03:22 PM
  #40
Randyb12's Avatar
Randyb12
Is the 330 a FT or FE?
Old Nov 15, 2005 | 03:34 PM
  #41
rusty70f100
It's an FT.
Old Nov 15, 2005 | 03:40 PM
  #42
Randyb12's Avatar
Randyb12
Thanks, Russ.
Old Nov 15, 2005 | 04:43 PM
  #43
ford390gashog
heres a thought. could i use a 390 crank with these rods and pistons? just be interesting to do.
Old Nov 15, 2005 | 05:20 PM
  #44
Randyb12's Avatar
Randyb12
No, you need the short rods for the bigger crank.
Old Nov 15, 2005 | 10:43 PM
  #45
ford390gashog
rusty,
what does a stock block weigh? this one seems very heavy. i picked the block up by myself and it seem almost undoable. i weighed it on a scal from my hoist and it weighed 291 lbs with crank. i think a sbc 350 weighs 130 without crank. what a difference. i did the oiling mods to the block to.
