Overdrive, a final answer
Old Mar 10, 2002 | 02:06 PM
Mil1ion's Avatar
Mil1ion
Old Mar 26, 2002 | 01:46 AM
phaffy12's Avatar
phaffy12
There have been endless posts about getting an overdrive gear in our older trucks. So far I have been more confused than anything. I have a '76 F-150, 4x4 (married t-case), 390 bolted to a C6. What are my options for gaining an overdrive gear or at least a little more efficiency at highway speed?
Old Mar 26, 2002 | 08:50 AM
rc351w's Avatar
rc351w
I don't know that there was ever a stock setup for your application but [http://www.gearvenders.com] may have a setup that would work. They specialize in under/overdrive add-on boxes.
Old Mar 26, 2002 | 02:13 PM
leadmic's Avatar
leadmic
Their is a co. called lentech that builds an AOD overdrive that will bolt behind an FE engine.Its pricy through about $3400.00 but that includes a heavey duty torque converter and many mods and improvements. The tranny is supose to be good for 700H.P.
I think its www.lentech.com.
hope this helps leadmic
Old Mar 26, 2002 | 04:30 PM
Fastcat's Avatar
Fastcat
Gear vendors also makes an add on overdrive for the c6. it's about $2300. They advertize in most hot rod mags.
Old Mar 26, 2002 | 11:44 PM
phaffy12's Avatar
phaffy12
There was a post awhile back about Clark 5-speeds. I would actually like to go manual and as I understood it, some came with an overdrive gear. Are there any around with an FE bellhousing and if so, where do I find one(since they came out of dump trucks and such).
