Sponsored by: Real Truck
tow command system
Old Nov 10, 2005 | 06:14 PM
SAYERS's Avatar
SAYERS
tow command system
I have a 05 f350 4x4, diesel with the tow command system. When I am pulling my trailer about 2500 pounds with equipment about 5000 pounds I am getting a tone or beeping. It does not tell me to check trailer and the braking works fine, I have checked the connection and it is also ok. Anyone else have or know whats going on ? thanks
Old Nov 10, 2005 | 07:15 PM
tvsjr's Avatar
tvsjr
Do you have the reverse parking sensors? If so, you need to disable it using the big "P" button near the 4WD control. Depending on the trailer, you may notice the beeping getting faster/going solid tone when in a corner, as one edge of the trailer is getting closer to the bumper.
Old Nov 10, 2005 | 09:16 PM
cterrysgd's Avatar
cterrysgd
I had that problem and found that if you watch closely when it makes the beeping sound that the trailer disconnected sign flashes quickly on the brake controller.
I inspected my plug on the trailer and found a few loose wires. Bought a new plug b/c the old one was beat up and haven't had a problem since.
Good luck! Hope this helps.
Chris
Old Nov 11, 2005 | 05:06 PM
SAYERS's Avatar
SAYERS
tow command system
to tvsjr, no I do not have the rear sensor, I forgot to list the truck but I have the xl model, thanks anyway.
