1978 - 1996 Big Bronco
Fuel Gauge
Old Nov 10, 2005 | 09:03 AM
MichSandSquid's Avatar
MichSandSquid
Fuel Gauge
I know I'm going to get blasted for not using the FAQ's , but I did and received no results on fuel gauge.
I just replaced the fuel tank and the sending unit, on a 88 in the rust belt, you do one you do both. Anyways, now that I have these in, my fuel gauge is not responding, even tho I stopped and put 27 gallons of fuel in it on my way home fromt he shop. Any helpful hints as to why the gauge would stop working?
Thanks
Steve
Old Nov 10, 2005 | 09:42 AM
Kemicalburns's Avatar
Kemicalburns
check for power to the gauge and power from the sender connector back on the pump. you did hook the electrical back up. (sorry gotta ask)
Old Nov 10, 2005 | 09:45 AM
MichSandSquid
Actually, I did not put the tank back in, my Uncles did and they're even more **** about stuff than I am. I have to ASSuME that they did.
Old Nov 10, 2005 | 11:55 AM
Kemicalburns
well i would crawl under there and make sure. maybe even add some dielectric grease to make sure there is good contact. asumptions are the mother of all F ups
Old Nov 10, 2005 | 12:25 PM
MichSandSquid
I was going to do taht tomorrow night after work. They're real good about double checking each other and they always add dieletric to all of thier electrical connections. They're the ones who made that impression upon me to use such a "inexpensive" item liek that.
Old Nov 14, 2005 | 11:06 AM
MichSandSquid
Well it turns out that the sending unit in the new assembly is bad. After I pull the plug from the tank, the fuel gauge goes to Full, but as soon as I put it back on, it pegs to below Empty. Looks lIke I have to drive it to empty the tank so i can put another new fuel sending unit in. Thanks for everything.
Old Nov 14, 2005 | 12:38 PM
Kemicalburns
buy the part from ford. that way you dont have this issue again. But you know it could also be your float that is bad. when i did my replacment the float was cracked and had fuel in it as well. the whole unit had 180k miles on it so i replace the whole thing from ford $162 complete with pump,sender,float. was the only way to go
Old Nov 14, 2005 | 12:54 PM
MichSandSquid
I paid $100 for a new unit from the auto parts store. When I called the local dealer, he quoated me $162, then when I called the other dealer close to here, he said, "That is a dis-continued item". But my new sending unit came complete also.
Old Nov 14, 2005 | 06:59 PM
Katmandu's Avatar
Katmandu
Question
Can you buy the sending unit withOUT the fuel pickup tubes etc...
Are there any other Models that the fuel sender will work from ??
Old Nov 15, 2005 | 07:28 AM
MichSandSquid
Unfortunately, every placed that I talked to (about 8) said it was a complete assy. I had to replced my assy because of being north of the rust belt, when I replaced the tank, we inspected the tubes and they were rust through also.
Old Nov 15, 2005 | 07:57 AM
Katmandu's Avatar
Katmandu
Question
Where can sending units be bought for CHEAP ??
Old Nov 15, 2005 | 08:04 AM
MichSandSquid
Cheap???? There is no such thing for a sending unit, but I thought $100 was very inexpensive. I had to replace one in anther van and it cost me almost $200. Only thing I can say is check your local auto parts stores. I wouldn't go through a junkyard up here because they would all be in the same shape as what I had.
Old Nov 15, 2005 | 11:34 AM
Katmandu's Avatar
Katmandu
Thumbs up
Found one for $88.xx here --->> http://www.rockauto.com/
Old Nov 15, 2005 | 11:38 AM
MichSandSquid
[QUOTE=Katmandu]Found one for $88.xx here --->> http://www.rockauto.com/[/QUOTE]
I called them and they didn't have one for a 88 Bronco......
Old Nov 15, 2005 | 12:40 PM
Katmandu's Avatar
Katmandu
[QUOTE=MichSandSquid]
Did they say they could get them ??
Their On-Line Catalog shows them for $88.xx
