1999 7.3 with P1280 & P1670 code
Old 11-09-2005, 07:05 PM
shopsteward's Avatar
shopsteward
shopsteward is offline
I just started have a problem with my Ford 1999 7.3 F-350. I was driving down the freeway and the engine just quit. While it was still moving, I turned the engine off and then on again and it seem to correct the problem. Then within a mile, it did it again. Again I turned the engine off and on again and it seemed to correct the problem. Sometimes it run fine and next it will just quit. Sometimes it will not want to start, but if I turn the key off then on again, it will start and run fine. The "service engine soon" light is now on. I have had the computer modified and the same instrument that installed the new program can also read engine codes. It noted a P1280 & P1670 code. Any help will be appreciated.
Thanks
Shopsteward
Old 11-09-2005, 07:10 PM
blueeyes2478's Avatar
blueeyes2478
blueeyes2478 is offline
I would say CPS camshaft postioning senser.But i might be wrong.
Old 11-09-2005, 07:11 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
sounds to me like a Camshaft Position Sensor. search around this forum with CPS or CMP (acronyms for it) and see if you have any of the symptoms that are shown. that is my .02, ill let some others chime in.
Old 11-09-2005, 08:34 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Powerstrokedlariat is offline
Sure sounds like a CPS sensor to me. Your codes mean- P-1280= ICP circuit out of range
P-1670 EF signal not detected
Start with the CPS, probably fix everything
Old 11-09-2005, 10:26 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
4X4 IN REFUGIO is offline
Did You Say Camshaft Position Sensor !!!!!!!!!!
Ford Should Have Done A Recall On This And Replaced The Sensor With One That Doesn't Wear Out. Or They Should At Least Supply You With A Spare.
The Give You A Spare Tire.......i Think The Sensor Cost About As Much As The Tire Does!!!!!!!!
Old 11-22-2005, 11:45 AM
Mike's Auto's Avatar
Mike's Auto
Mike's Auto is offline
I have the same problem with mine and the CPS was the first thing I thought of replacing. It's still doing the same thing and I was wondering if there is any other reason any of you guys would know about. URGENT!!! Thanks
Old 11-22-2005, 04:55 PM
shopsteward
My son has the truck at this time. We are going to get a new CPS and see if that fixes the problem. If this resolves the problem, should the "check engine soon" light go out?
Thanks
Old 11-22-2005, 07:25 PM
Batgeek's Avatar
Batgeek
Batgeek is offline
Hay Mikes Auto if you bought your CPS from autozone they may have sold you the wrong one. They have the same part # for every 7.3 powerstroke made. If you look through some of the other postings here they state the CPS is different depending upon the # on the engine. I know this all to well because they sold me the wrong one. An easy way to tell is if the CPS feels a little loose in the hole its the wrong one the right one will fit nice and snug.
Old 11-22-2005, 07:36 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome shopsteward & Mike's Auto to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 11-22-2005, 08:38 PM
Mike's Auto
Batgeek, thanks for that reply to me...I bought the part at Carquest but maybe they did the same thing as Autozone did. I'll get right on that. Thanks.
Chris
Old 11-23-2005, 11:48 AM
Mike's Auto
Talking It works!!!
Sweet!!! After buying two CPS 's from Carquest and them not working I got one from the Ford dealership and it works. I only wish I would have known what you knew earlier Batgeek. Thank you so much!
Old 11-23-2005, 01:40 PM
Batgeek's Avatar
Batgeek
Batgeek is offline
Hey, I found out the hard way to. After I tried my first two I checked out this site and did some research and went back to the Zone. They had no idea what I was talking about, but gave me my money back no problem. They said that was just like Ford. I was lucky my truck was still covered under the 100,000 mile warranty. Three days with the wonderfuly talented Ford tech's and $100 she ran fine. Most of the chain auto parts stores have it wrong. I just know Ford's behind that somehow.
Old 11-30-2005, 06:51 PM
shopsteward
Well, my son took the truck in to be checked and relaced the fuel pressure sensor. That seems to have solved the problem. No more "check engine light".
Thanks for the responses.
Old 12-01-2005, 11:46 AM
Wings's Avatar
Wings
Wings is offline
Is the fuel pressure sensor and the injector pressure sensor (ICP) the same thing? Just couldn't find it on the electrical schematic.
Old 12-02-2005, 03:09 PM
shopsteward
It was an Injector Pressure Sensor.
Quick Reply: 1999 7.3 with P1280 & P1670 code
