1999 7.3 with P1280 & P1670 code
Code p1280 is the Injector Control Pressure Sensor (ICP) sensor (CKT Low) , it is located behind the altenator , this costs $259.99 at Advanced Auto . In order to replace it you have to remove the belt and the three bolts that hold the alternator and after negative cable is disconnected move altenator out of the way and use an open end wrench to remove ICP Sensor . First off though clean the connection really good inside to see if oil in the connection is the problem . GOOD LUCK !!
digitaldemon
01-28-2013 03:19 PM
starwriter
01-28-2008 02:12 AM
Stroke'NPower
1999 to 2016 Super Duty
16
12-01-2007 06:27 PM
michaels
09-15-2007 07:29 PM
mblalock
Bronco II
09-04-2006 09:53 PM
