1978 - 1996 Big Bronco
351 rear end fluid
Old Nov 9, 2005 | 06:18 PM
sharkwhit's Avatar
sharkwhit
351 rear end fluid
does anyone know what type of fluid to use in 95 bronco rear end and does diff cover use a gasket or sealant?
Old Nov 9, 2005 | 06:57 PM
aurgathor's Avatar
aurgathor
80W90 dino, 75W140 synthetic, etc.
It can use either a gasket, or a bead of sealant.
Old Nov 9, 2005 | 07:28 PM
93BigBlackBronco's Avatar
93BigBlackBronco
I'll 2nd that.
I just ordered Royal Purple synthetic from Summit good price under $5.00 a quart.
I am regearing to 4.11.
Old Nov 9, 2005 | 08:34 PM
sharkwhit's Avatar
sharkwhit
what does the book call for gasket or sealant
Old Nov 9, 2005 | 09:21 PM
93BigBlackBronco
I've had better luck with sealant no drippy
Old Nov 9, 2005 | 11:21 PM
aurgathor's Avatar
aurgathor
The book calls for "a continuous bead of Silicone Rubber D6AZ-19562-AA or BA or equivalent"; however, I believe the axles come with gasket from the factory.
Old Nov 10, 2005 | 08:45 AM
Kemicalburns's Avatar
Kemicalburns
do you have a limited slip in there? if so you need to add the friction modifier fluid as well otherwise you will toast that 8.8 in no time
jdq1986
Oct 28, 2016 04:46 PM
Ford4Life04
2004 - 2008 F150
Jun 16, 2016 08:51 PM
twall_SD250
Jun 16, 2016 08:49 PM
Bobird
Large Truck
Oct 14, 2014 10:48 PM
RobertJohn
Nov 21, 2010 10:35 AM
