Sponsored by: Auxito
highbeams
Old Nov 9, 2005 | 12:46 AM
taylor1000rr's Avatar
taylor1000rr
Post highbeams
I have a 2002 F-150 standard p/u. Highbeams not working when I pull lever back when the lever is pushed foward there is no lights at all. Found this out when I went to get inspection. Do I need to replace switch or is there a relay that can cause this problem
Old Nov 9, 2005 | 10:00 AM
lancekilgore's Avatar
lancekilgore
You can either replace or rebuild the switch there is a thread in the FAQ's https://www.ford-trucks.com/forums/s...B%25252Bremove
try that link it will tell you how to remove and clean.
Lance
