Which Fe Do I Have???
Old Nov 8, 2005 | 07:49 PM
smoker9000's Avatar
smoker9000
How can I determine which fe engine is in my truck? I was told it was a 390.
Old Nov 8, 2005 | 07:54 PM
fordeverpower's Avatar
fordeverpower
stroke test my friend, theres a small article in ratsmoker's FAQ.
Old Nov 8, 2005 | 08:39 PM
gtex's Avatar
gtex
if you're convinced it is the original engine, then the VIN will tell you. Otherwsie, you gotta measure the stroke or ID the crank.
Old Nov 8, 2005 | 09:02 PM
smoker9000's Avatar
smoker9000
so the bore has nothing to do with it?
Old Nov 8, 2005 | 09:12 PM
fordeverpower
sure, pull the the heads if you want.
Old Nov 8, 2005 | 09:25 PM
fordraceboy's Avatar
fordraceboy
the chances are pretty slim you got a block with a bore other than 4.05... JMO
Old Nov 9, 2005 | 10:17 AM
Mike G's Avatar
Mike G
Unless it's a 65-67 truck..... Once the stroke of the crank is identified, then you can pretty much fill in the blanks from there. You will have two choices, a 352/360 (that's were the bore dimension comes in) or a 390.
--Mike
Old Nov 9, 2005 | 01:30 PM
1975Ford's Avatar
1975Ford
It's like Gtex said, "gotta measure the stroke or ID the crank"
