Sponsored by: Real Truck
clutch pedal problems
Old Nov 8, 2005 | 04:26 PM
suprdutytim's Avatar
suprdutytim
Question clutch pedal problems
hey guys I'm turning to the pros AGAIN,
here it goes i have a 2000 f350 with a six speed my problem is the 10 cent plastic clip that holds the rod to the pedal I've been thru three of them in the last two months. I have'nt been driving any different than usual.this could be a serious problem its come apart while i was driving several times almmost causing three accidents. Has anyone found an aftermarket clip that is better than the s*^& ford stocks if so please HELP point me in the right direction
thnx suprdutytim
Old Nov 8, 2005 | 04:38 PM
FortyFords's Avatar
FortyFords
I haven't seen anything to replace it.
But maybe you have a alignment problem with the pedal to pushrod causing a skew when pushed in. I believe there are some bolts that hold the pedal bracket in place maybe it needs to be adjusted.
Rich
Old Nov 8, 2005 | 05:00 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Check this thread:
https://www.ford-trucks.com/forums/s...d.php?t=425737
One of those guys should be able to get you on to the fix.
