edge with attitude platnum
Old Nov 8, 2005 | 03:12 PM
05f250powerstrok's Avatar
05f250powerstrok
with jsut the edge with attitude what psi do you run at
Old Nov 8, 2005 | 03:37 PM
superfast6.0's Avatar
superfast6.0
the highest ive hit is about 33 PSI
Old Nov 8, 2005 | 06:28 PM
jasonschwenk's Avatar
jasonschwenk
i have mine set to back off about the same
Old Nov 8, 2005 | 07:35 PM
05f250powerstrok
what type settings are you useing mine hits 26 and stops like a wall
Old Nov 8, 2005 | 09:55 PM
plaidcow's Avatar
plaidcow
same here. i top out about 26-27 psi. dont have the platinum, just juice w/attitude set on level 5 and low boost adj. on 5 with predator on 65 hp. just added the predator recently but even before only 26-27 psi. does this have anything to do with the fact that i have the boost limit set on 27? should i set it higher to open the threshold or does it not work like that...
