Gas gauge question
This problem occurs regardless of which tank I am using, front or rear.
When the fuel level in the tank I am using drops below about 1/4 tank, the gauge works ok. If I have more than 1/4 tank of fuel, it reads more than full. It pegs all the way over on the full side.
Since it does this with both tanks, I thought it might be a problem with the gauge itself. Does that sound right? Or have both of my sending units failed in the exact same way?
Any info would be greatly appreciated.
Ford uses 75 ohm fuel senders. So a full tank would be 70-75 ohms, empty would be 0-2 ohms.
Now there are two problems with this.
First, many aftermarket replacement senders use the same element, in different housings, thus saving manufacturing costs. Many of them use a 90 ohm element. So if your tank's have aftermarket senders, "full" will be "way past" the full mark.
Also, because the more resistance there is, the higher on the scale the needle goes, the aging of the wires, poor grounds and so forth, add to the resistance. The fuel sender is grounded at the tank - so the stuff between that ground, and the ground on the firewall for the cluster, is a lot of potentially rusty stuff. The tank hole plate it mounts to, the tank itself, the tank straps, the frame, and the body bolts/ground strap under the hood.
It's not uncommon for the fuel gauges to drift as the vehicle ages. To test this, run one of your tanks to "E", essentially empty, but not empty enough to stall the engine and plug the fuel filter. Then disconnect the battery, pull the cluster, and measure the resistance between a good ground on the firewall, and the wire in the connector that's for the fuel gauge. Flip the tank switch to each tank, one should have a very small resistance depending how empty the tank is, and the other should be 70-75 ohms if it's completely full.
If you do have "correct" readings on your ohm meter (testing at the cluster connector), then it's the gauge itself (unlikely).
If you have incorrect readings at the cluster connector, you can drop one of the tanks and measure at the fuel tank itself. If it's correct there, then you know it's ground related. If it's incorrect at the tank, then you know it's the sender itself.
This is why garages will charge some money for this... measuring it at the tank is difficult because most people have hands that don't fit between the bottom of the bed and the top of the tanks to disconnect and reconnect the connector. I was able to do this on my side tank, but not the rear tank. My hands are "medium" I guess !?
I had the bed of my truck off for part of the summer doing body work so I decided "screw it" and replaced both pumps and senders, so I don't have to think about failure in either tank for years to come. I hate spending money that I don't need to, but I hate taking out gas tanks even more.
If the senders are bad I will try getting a few from the local trucks only junkyard for a few bucks each, before I drop all that cash on new ones.
It seems to me that I have a universal sender around here somewhere that came with my Dakota Digital Gauge set for another car. Maybe I will try that as well. Does not cost anything to test it!
Shrug - no problem. I went through this (more or less) when I was grafting in a t-bird digital cluster into my truck.
I shudder to think what it will cost to fill it up at $2.48 a gallon!
I can only imagine it will cause me more heartbreak by getting about 6 mpg!
I like my Taurus. 19mpg. I know there are more economical cars, but I am to big to wedge my butt in to a Hyundai. The Taurus is just the right size for me.
Thankfully most days my wife and I will be sharing the car. She only works about two miles from my school. (School! At my age! AACCCKK!)
Your truck should do better than 6. My old tired crewcab gets 12-15 depending on how I drive.
We did make one drive from Phoenix to Los Angeles and got about 28 mpg then.
Traffic is a bit*h! I miss my old 53 Chevy with the 235 straight six. 21mpg city!
So you really think that big ol extended cab truck with the 351 w/edelbrock carb will do that well? I will be shocked to see it.
Others have had better and worse results than me... with their trucks... but I cannot complain about my mileage, considering it's an F350, and a crewcab, and weighs in at 6997 lbs.
