Computer Chips & Tuners
Major EFI problem
Old Nov 7, 2005 | 07:57 PM
apropos's Avatar
apropos
Major EFI problem
1996 Mazda 626 ES 2.5L auto. (It's nearly identical to Ford Probe)
I replaced the starter, which entailed disconnecting the throttle body and stuff around it like fuel lines, coolant lines, accelerator cable, etc. When I got everything back together, the starter worked but the vehicle will not idle and runs very rich. I pulled the codes and I got:
P0100 - MAF circuit malfunction
P0110 - IAT circuit
P0125 - "Excessive time to enter closed loop fuel control".
PO135 - O2 sensor heater circuit malfunction
P0300 (Or PO303) - Random misfire detected on cylinder 3 - I replaced that spark plug and cleaned up the oil in its cavity so I don't think it's an issue anymore)
P1170 - Heater O2 sensor (Front RH (Inversion))
Any idea what any of this means? The car runs horrible, does not idle (goes anywhere from 0 to 2000 rpms) and gets less than 20mpg on highway instead of close to 30mpg.
I pulled the MAF sensor and looked at it, although not sure what I was supposed to look at.
Old Nov 15, 2005 | 02:36 PM
FTE Ken's Avatar
FTE Ken
May want to try a Mazda or Probe web site. This section is dedicated to aftermarket chips and tuners.
Sgt93
6.7L Power Stroke Diesel
Feb 5, 2018 12:48 AM
droff85
Jan 31, 2012 08:19 PM
sin
Oct 21, 2009 12:19 PM
applehead
20
Dec 8, 2007 11:49 PM
thavngr98
Aug 14, 2007 11:21 AM
