repainting new wheels
Old Nov 7, 2005 | 06:51 PM
aurgathor's Avatar
aurgathor
I'll be receiving a set of white steel wheels (16x7) tomorrow, but I want them painted silver. (only had white/black/chrome available, so ordering silver wasn't an option).
Questions:
a) other then carefully cleaning off grease/dirt/glue/whatnot, is there anything else I need to do before painting? Specifically, do I need to use a primer, or is there some benefit of using one on a wheel that has already been painted?
b) what's the best for degreasing?
c) what kind (brand) paint would be the best to paint a wheel? (I got Schuck's, NAPA, Autozone, Pep Boys, Home Depot, Loews, Wal Mart, K-Mart, etc., all within reasonable distance, so there's plenty to choose from) Obviuously, I want a paint that resists rocks and debris as much as possible, and is not harmed by ordinary automotive chemicals such as break fluid or gasoline.
TIA
Old Nov 7, 2005 | 07:06 PM
frederic's Avatar
frederic
scratch the existing paint lightly with sandpaper in the 220-300 grit range, being careful not to go through the paint (which is probably powder coating, actually). Then prime, and paint as you would any automotive part. Any of the dupont, krylon etc automotive rattle can paints would be fine, though you probably could get away with a rustoleum if you're painting a light color like silver. Wheels get chipped a lot so expect to repaint them here and there, or at least touch them up once in a while.
For degreasing I use one of those orange-based hand cleaners, then wash thoroughly. takes the grease right off, and it's not too expensive. Even oxy clean works if you dilute it a little less than the container suggests.
Old Nov 8, 2005 | 05:58 AM
Geneoh's Avatar
Geneoh
If your lookin for a nice clean job that will last awhile, you might want
to look into having them Powder Coated.
I think for the time and effort and cost to do it yourself you might as
well have them P-C if you want a clean lasting job.
Old Nov 8, 2005 | 05:11 PM
aurgathor's Avatar
aurgathor
These are some inexpensive ($40) wheels, so I don't want to spend too much extra money on them. And I don't know anyone doing powder coating in my area either.
Old Nov 17, 2005 | 12:42 PM
aurgathor's Avatar
aurgathor
In retrospect, after 2 cans of primer and 3 cans of wheel paint from Schucks, I think I may have been better off by getting a different set of wheels that would've come in silver. But it's too late the think about, and the wheels do look a lot better then they did before, and now they are doubly coated. However, I noticed on the lips that the paint isn't very durable. Is there anything I can do about that, like baking the wheels in the oven at some set temperature?
TIA
Old Nov 17, 2005 | 05:12 PM
Geneoh's Avatar
Geneoh
Baking them wont do anything for durability.
I got one other tip for ya, you might try a can of Clear Chip Guard.
This stuff is made to spray on your rockers (rock protection)
It will most likely have a bit of texture to it though.
Like you said your in to deep now, but Powder Coating anit all that much.
Gene
Old Nov 18, 2005 | 10:01 PM
aurgathor's Avatar
aurgathor
Will see is Schucks or Napa has that stuff. I plan to get some forged aluminium wheels next year, and they'll definitely get powder coating.
cberry
35
Dec 1, 2014 02:16 PM
SaikotikGunman
Mar 12, 2010 10:19 AM
Nightrain
39
Aug 3, 2007 10:07 PM
66f100352
Oil & Lubrication
May 9, 2004 02:08 AM
Ken2600
Paint & Bodywork
Mar 13, 2004 04:34 PM
