Yoke Slop?
Old Nov 7, 2005 | 05:51 PM
88FordF-150's Avatar
88FordF-150
Question Yoke Slop?
On the yoke going into my rearend on my 88 ford f-150 I have noticed some slop in my rear yoke any way to correct that?
Old Nov 7, 2005 | 08:11 PM
kotzy's Avatar
kotzy
You say slop, I take it you mean play. Which way rotational or sideways up and down?
Old Nov 8, 2005 | 06:43 AM
88FordF-150
sideways it has "play" in it.
Old Nov 8, 2005 | 07:10 AM
kotzy's Avatar
kotzy
So when you get ahold of the yoke you can move it from side to side, not a tuning
type movement would mean the pinion bearings are loose. If it just turns a bit it is lash
in the ring and pinion along with the lash in the differential gears as well as
any play in differential side gears to axle splines. I would not worry about
it if you cannot rotate the yoke more than around 22 to 30 degs.
The sideways or up and down movement/ bearing problem would need to be looked into. Pinion seal will begin to leak, and noise will develop. Hope this helps.
