Spider Gears
Old Nov 7, 2005 | 04:20 PM
Thomasm67's Avatar
Thomasm67
Spider Gears
Okay took the cover off and will have to replace the spider and side gears to even weld it just to many teeth missing. But the axles have to be pulled the pin will not come out otherwise but oh well and then after closer inspection of the ujoints at the nuckles those will be replace by bigger and better ones. i took pics but they were blurry and you couldn't see anything. So i will keep posting on this thread on the progress.
Old Nov 8, 2005 | 05:38 PM
Thomasm67's Avatar
Thomasm67
Okay Got in the Mood and replaced my back 2 shocks on the Beast.
Old Nov 10, 2005 | 02:43 PM
HappyJack's Avatar
HappyJack
Progress?
Old Nov 10, 2005 | 07:47 PM
Thomasm67's Avatar
Thomasm67
A lil progress this coming weekend i'm having my uncle put in my new front leafs from Skyjacker while i'm at the G2G. Next week it goes in to have the front gears replaced and welded front and rear.
Old Nov 10, 2005 | 07:56 PM
HappyJack's Avatar
HappyJack
Way cool!
Old Nov 10, 2005 | 10:00 PM
97Centurion's Avatar
97Centurion
Rub my Belly
Sounds good! I hate it when it gets dark earlier. Cuts into my wrenching time.
Old Nov 12, 2005 | 09:50 AM
Thomasm67's Avatar
Thomasm67
Okay it's a sad day my engine blew up when i was taking it to my uncles place so unless i go buy the 390 i found for $100 my 76 won't be at tuttle but i will be there with my 87.
Old Nov 12, 2005 | 09:57 AM
HappyJack's Avatar
HappyJack
Man that's too bad. Gona miss old smokey.
Old Nov 13, 2005 | 08:38 PM
Thomasm67's Avatar
Thomasm67
More Bad news i was 20 minutes late calling on that 390 it was sold just 20 minutes before i called.
Old Nov 14, 2005 | 06:34 AM
Peties3's Avatar
Peties3
I think someone here was selling a 360. I know the 390 would be better. You could really do some digging and maybe come up with a 428 CJ too!!! That would be cool!!!!!
Mark
Old Nov 14, 2005 | 06:43 AM
Thomasm67's Avatar
Thomasm67
Yes it would but i can turn the 360 into a 390 by boring and stroking it gonna use the 390 heads and crank from my old engine.
Old Nov 14, 2005 | 03:18 PM
Peties3's Avatar
Peties3
I think the bore is the same. The stroke is the difference. Pretty sure on this.
Mark
Old Nov 14, 2005 | 03:34 PM
Thomasm67's Avatar
Thomasm67
Nodz probly so the 360 is just destroked 390 but anyway it's gonna be an animal of a engine.
Old Nov 14, 2005 | 08:17 PM
Thomasm67's Avatar
Thomasm67
Since i will rebuilding a motor it was recommended that i get H beams rods if the motor i hope to get doesn't have them.
