Replacement Carb
Old Nov 7, 2005 | 01:53 PM
qman's Avatar
qman
Replacement Carb
I have a 72 F100 360 with rebuilt 2bbl Motorcraft style carb. I have some idle and fuel leakage problems due to the butterfly shaft having wore a spot in the carb body and was thinking of buying another. I don't really want a 4bbl carb just cause I don't want to have to get another manifold. Does Holley or Edelbrock make a replacement for this 2bbl carb? If so is it just a swap or are there mods necessary to make it work?
Old Nov 7, 2005 | 03:26 PM
ramtoo's Avatar
ramtoo
Holley makes a 2300 2 bbl Its a bolt on replacement. It is a manual cable pull choke very easy to work on also. You can get it in either 350 cfm or 500 cfm
Old Nov 7, 2005 | 04:48 PM
ford390gashog's Avatar
ford390gashog
yep. www.summitracing.com sells them for 239.00
