Ignition Troubles
Old Mar 27, 2002 | 09:34 PM
Low56's Avatar
Low56
Ignition Troubles
I have a 75 F 100 with a 360 2 barrel.
The truck will start cold and run fine but when you shut it down and let sit a few minutes it will not start back up.
I have checked and it is not getting any fire.
If you let it sit about 20-30 minutes it will start back up.
I have replaced the ingnition control module (Twice), the rotor button, distrbutor cap, plugs, wires, coil,and condensor.
I have not replaced the Stator yet but that is next on my list.
Any ideas?
I am going nuts over this one.
Thanks for any help you can offer,
Todd Morrison
Old Mar 27, 2002 | 09:42 PM
lshort's Avatar
lshort
Ignition Troubles
The pickup coil is a common problem, you schould have a reading of around 80 ohms between the orange and purple wires comming from the distributor, also there schould be no reading from these wires to ground if not the coil is bad.
Old Mar 28, 2002 | 10:00 AM
dzjammer's Avatar
dzjammer
Ignition Troubles
Check the solenoid, it should give you 6-8 volts when running and 12+ when starting. This is at the coil. I had one that would give out 1 volt when trying to run, it also was bleeding juice through to the starter all the time.
Old Mar 28, 2002 | 10:32 AM
beartracks's Avatar
beartracks
Ignition Troubles
The ignition switch is another possibility. It's contacts might heat up if they are old and decrepid.
Bear Tracks
Old Apr 4, 2002 | 10:49 PM
bottlecap's Avatar
bottlecap
Post Ignition Troubles
replace the ignition control box they overheat and shut down
Old Apr 5, 2002 | 02:13 AM
Mil1ion's Avatar
Mil1ion
Ignition Troubles
