Console temp sensor not working on Explorer
Old Nov 7, 2005 | 10:45 AM
leafian's Avatar
leafian
Hi,
My console outside air temp always reads 60C (140F).
Sounds like it coud be the temp sensor.
Where is the sensor located? Wire colours?
Could I remove the one on my 94 Limited and put it on the 97 Limited?
Old Nov 7, 2005 | 02:12 PM
Franklin2's Avatar
Franklin2
I am going off a 99 diagram.
The wires are darkblue/white and darkblue/yellow. The location is under the hood, driver's side front, in front of the radiator.
Old Nov 12, 2005 | 08:57 AM
leafian's Avatar
leafian
Thanks, I was able to find it this morning.
Removed the sensor and instead of it showing 60C it showed -40C so I knew I removed the right one.
I then went to my 94 Limited and removed it and put it on my 97.
It showed 9C. Sweet!
I wonder if that will fix this clicking sound I hear whenever I have the heat on.
It sounds almost like the AC compressor cycling on/off every 5 secs.
