99 expedition stalls
Old Nov 7, 2005 | 08:54 AM
mb51's Avatar
mb51
my 99 expedition stalls when started and will run fine if you apply the throtle but stalls as soon as you remove throttle pressure any ideas?
Old Nov 7, 2005 | 10:29 AM
l-m tech's Avatar
l-m tech
probably a sticking closed iac motor.it controls the idle of the engine.also check for pcv vac. leaks to.
Old Nov 8, 2005 | 10:11 AM
BigMan69's Avatar
BigMan69
I agree,,,,,sounds like an Idle Air Control Valve. They seem to go at about 50,000 miles, so if yours lasted longer, consider yourself lucky. If I remember, about $45.00 and an easy job.
BigMan69
