Oil Pan
Old Nov 6, 2005 | 07:34 PM
Haaser's Avatar
Haaser
Question Oil Pan
Hello
I bought a 1973 econoline 200 with a 302 for my 1965 mercury. The engine has a rear sump oil pan. Will it fit in the engine comparment without hitting the prop. vavle for the disk brake on the cross member. Simply will the rear sump fit?
Old Nov 6, 2005 | 08:16 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
I say that it will fit, I have used rear sumps in these trucks many times,
although I have not used one from an econoline, as high as these engines
sit in the chassis I don't see a problem! I do know that the econo is
mid engine.
P.S with the rear sumps, when it's time for a oil change, it sure drains easy!
no puking on the front crossmember!
