05 250 Question
Old Nov 6, 2005 | 05:57 PM
05f250powerstrok's Avatar
05f250powerstrok
05 250 Question
I Have The Edge With Attitude Platnium And For Some Reson My Psi Is Maxing At 26 Psi A Buddy Of Mine Has The Same Thing And His Is At 31 Or 32 Ish Why Is Mine Maxing At A Lower Number I Got The Max Boost Set To Like 31.. On The Attitude. Any Help Would Be Great Also What Type Of Milage Are You Guys Getting On The 05 I Got 35's And Im In The 10 -11 Range Everyone Is Telling Me I Should Be Getting Better Than That..
Old Nov 6, 2005 | 06:09 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
The 2005 model trucks have significantly lowered stock boost tables.
Despite what the module manufactures like to make you believe, the fuel modules DO NOT MANIPULATE boost by any other means than extra fuel and timing. The boost can be adjusted quite drastically with the VGT- a function which no present fuel boxes (and only one tuner, from one particular vendor) properly manipulates.
Old Nov 6, 2005 | 06:19 PM
05f250powerstrok
alright the main thing that is getting me i had the regular edge isntalle don it orginally and i had a lot more power than i do now.. like in extreme i did the 1/4 mile thing and i was like 16.9 which isnt very quick ... and 0 -60 was like 9.3 seconds
Old Nov 6, 2005 | 09:04 PM
tn mac's Avatar
tn mac
keep the edge and say goodbye to your tranny, good luck.
Old Nov 6, 2005 | 10:36 PM
fordmann's Avatar
fordmann
MPG for 05
The worst I have gotten with my 05 psd which is a crew cab, lb, 4x4 is 12.9 going over the rockies with a light load. That is when it had 5 or 7 thousand miles on it. I went on a trip to middle KY running 80 -85 and averaged 19.4. It seems to me the more miles I put on the truck the better it gets. It has 18,480 on it now and is 10 1/2 months old. Not one problem with it. Just put a K&N filter charger on it two weeks ago. I will be putting dual exhaust on next. Will post again when I run 2-4 tanks thru it. The Fordman rides again!!
Never argue with an idiot. He'll just drag you down to his level and beat you with experience!
Old Nov 7, 2005 | 02:56 AM
f250ramkiler's Avatar
f250ramkiler
I would say your mileage is pretty bad. Is this from your trip computer or hand figured? The computers are notoriously wrong. I have and '05 F250 Harley edition with 36/14.50's on it and I average about 14mpg or so. Pretty disapointed especially with the price of diesel now and after owning a 7.3 that was getting 18 - 20 mpg. It may get bad fuel mileage but dang, it sure does look good!
Old Nov 7, 2005 | 06:59 AM
fordmann's Avatar
fordmann
After using a 76 F150 long bed 4x4 for all my heavy hauling. Which was a 390 4V, 4spd, 4.56 gears, 35" MT sidebiters, etc. etc. I was getting 6 or 7 mpg max. So anything over 10-15 mpg in my book is excellant. Thanks
Fordman
Old Nov 7, 2005 | 07:31 AM
05f250powerstrok
Its Hand Calced I Get Bout 250 Miles To A Tank
