oil pan ?
Old Nov 6, 2005 | 04:32 PM
Farmall05's Avatar
Farmall05
oil pan ?
I have a 82 f150 That I am trying to put a 400 out of a 78 F350 My question is dose any one know if the sump location needs to be changed I was test fitting it and it seemed realy too close to me
Old Nov 6, 2005 | 07:17 PM
fordborn's Avatar
fordborn
Welcome to Ford Truck Enthusiasts. In order to make it easier to navigate please read the following: Forum Guidelines
Inside certain forum's there could be a Read First: thread or threads attached to the top.
Please read these threads before posting.
In Addition to the Tech Forums there are State/Province Chapters that bring local members together for meets, events and just plain fun.
Once again...Welcome to the FTE Family
Old Nov 6, 2005 | 08:47 PM
Franklin2's Avatar
Franklin2
You are going to need a rear sump pan. If your engine is from a car, it probably has a front sump pan.
Old Nov 7, 2005 | 08:56 AM
Sycostang67's Avatar
Sycostang67
The 400 was available in 1982 Ford trucks, you might see if you can find a pic of a 400 oil pan in one of these trucks and compare it with the one you currently have.
Old Nov 7, 2005 | 10:21 AM
RR4E's Avatar
RR4E
Another question to think about. Did the engine come from a 2WD and is being installed in a 4x4 or the opposite? 4x4's generally have a different oil pan than 4x2's do, to allow for clearance of the front differential.
