F250 Spring Questions Help Needed
Old Nov 6, 2005 | 03:42 PM
71 Sport Custom's Avatar
71 Sport Custom
Hello, My 71 camper special has some sort of weird cantilever arm on the rear of the leaf spring? Is this due to the camper special, or something for this year? Do all f250's have this? I'd like to get some springs without it. There is a pic in my gallery marked "wrecker project". thanks
Old Nov 6, 2005 | 04:58 PM
banjopicker66's Avatar
banjopicker66
Check your e-mail.
That is indeed a cantilevered system, designed to give greater carrying capacity without increasing the number of springs.
It also was supposed to reduce the amount of sag as compared to an equally rated set of springs by reducing the flex - or so I was told many years ago.
Old Nov 7, 2005 | 02:20 AM
gtex's Avatar
gtex
I thought they called it the "flex-o-matic" suspension or such. I though it was there to smooth out the F250 ride.
Why would you want to get rid of it?
Old Nov 13, 2005 | 03:50 PM
71 Sport Custom
It's not that I really want to get rid of it. I was putting a One Ton dana 70 in it and figured I'd bring the bigger springs with the rear. I ended up with the rear going back a few inches as the one ton springs have the location pin/bolt set back a few more inches. So now I have to use the stock springs to get the location right. With this being a wrecker project I wanted the heavier springs. I didn't know if all f250's had this?
