Gear lube
Old Nov 6, 2005 | 11:55 AM
bully 515's Avatar
bully 515
Gear lube
hey guys looking to buy some gear lube for my rear axle. 1998 expy 4x4, any online spots for a cheap price. thanks...
Old Nov 6, 2005 | 12:55 PM
MisterCMK's Avatar
MisterCMK
Make sure you use synthetic, and the friction modifier for the limited slip.
Old Nov 6, 2005 | 01:13 PM
bully 515's Avatar
bully 515
ford say to use their brand only, is this true...
Old Nov 6, 2005 | 01:15 PM
MisterCMK's Avatar
MisterCMK
You don't have to. I bought the synthetic gear lube and friction modifier from my local Napa and haven't had any problems at all.
Old Nov 6, 2005 | 01:56 PM
ford390gashog's Avatar
ford390gashog
no but the gear lube you replace it with must be the same qauilty and meet or excced the specs. mobil does not say if they do or not but RP and RD meet the ford specs. try www.karlracing.com about 9.00 a quart and free shipping.
Old Nov 6, 2005 | 01:57 PM
ford390gashog
here is the specs
Old Nov 6, 2005 | 02:06 PM
EagleDakota's Avatar
EagleDakota
Since it only takes about 3 quarts for a fluid change, plus modifier, and is only done infrequently, if ever, why not just go with the Ford stuff? My 2000 Expy seems to not like anything unFord. Perhaps it is me, but I find that the Ford specs are very high and you know what you are getting.
Old Nov 6, 2005 | 03:38 PM
holiday187's Avatar
holiday187
use royal purple gear lube in the rear and you don't have to use the friction modifier......
