carb help
Old Nov 5, 2005 | 01:33 PM
jj22ee's Avatar
jj22ee
carb help
I just bought a holley carb it is 80457-2 600cfm what do i need to bolt this on my 1973 f100 with a 390 auto transmission.
Old Nov 5, 2005 | 02:16 PM
fordraceboy's Avatar
fordraceboy
as long as you got a four barrel intake it should be a bolt and go deal.... just hook everything back up the same, kickdown i'm not sure of as i run manuals...
Old Nov 5, 2005 | 08:44 PM
4starcstms's Avatar
4starcstms
I think everything comes with the holley to hook up the Automatic. Should tell ya in the info that came with the carb.
Old Nov 5, 2005 | 10:45 PM
jj22ee's Avatar
jj22ee
yeah I bought it at a swap meet today. So i don't have any info
Old Nov 5, 2005 | 10:51 PM
ford390gashog's Avatar
ford390gashog
lots of holleys don't have the ford kickdwon rod, also the carb should be rebuilt prior to use.
Old Nov 5, 2005 | 10:58 PM
jj22ee's Avatar
jj22ee
is a holley rebuild tough.
Old Nov 5, 2005 | 11:01 PM
ford390gashog
so then it has never been used?
Old Nov 5, 2005 | 11:04 PM
jj22ee's Avatar
jj22ee
It was bought by a guy in august but was only used for a couple of weeks he said. He claimed it was too small for his application
Old Nov 5, 2005 | 11:08 PM
ford390gashog
well being that it was used a rebuild is a good idea. you have no clue what is in there. also the gaskets shrink and leak once the fuel is gone for long periods of time. you will need to jet and install a PV to suit your application.is it vac secondarie or mechanical?
Old Nov 5, 2005 | 11:13 PM
jj22ee's Avatar
jj22ee
vac secondary
Old Nov 5, 2005 | 11:16 PM
jj22ee's Avatar
jj22ee
yeah I have no idea
Old Nov 5, 2005 | 11:22 PM
ford390gashog
can you tell for sure? what model is it?
Old Nov 6, 2005 | 11:40 AM
fordraceboy
they're not too difficult to rebuild... to get the right power valve you need a vacuum guage, run the truck at idle with the tranny in gear and the brakes on. divided the vacuum reading by 2 and then add .5..... thats the size of power valve you need...
Old Nov 6, 2005 | 12:29 PM
jj22ee's Avatar
jj22ee
it is a street performance vac secondary model 80457s
