Cps Tsb
Old Nov 5, 2005 | 10:17 AM
stroker2's Avatar
stroker2
Cps Tsb
Found this TSB (Technical Service Bulletin) info on the CPS (camshaft position sensor) on another forum site (tds, for those that are familiar with it). I know I had symptom #4 and replaced the CPS to correct it at 40K. It looks like I might have just been able to install a shim. Oh well, live and learn. I know I have read of other PSD owners having some of the other symptoms. Maybe it will save someone else the expense of a CPS. I haven't checked the price of the shim. I'm sure it's a dealer only part, but it has to be less expenseive than a CPS. It was listed as TSB 97-06-18, on that site, but 19970618 on this site under the 1997 F350 TSBs. If someone knows how to find this TSB on this forum with all this info, please let me know. I found the TSB, but it only gave some general problem info, and not this detail. Here's the info:
<TABLE border=0><TBODY><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TD style="FONT-WEIGHT: bold; FONT-SIZE: 11pt" vAlign=top width=230>LIGHT TRUCK:</TD><TD vAlign=top>1994-97 F SUPER DUTY, F-250, F-350
1995-97 E-350</TD></TR></TBODY></TABLE>
This TSB is being republished in its entirety to update the model years and include the latest level part. ISSUE:
The 7.3L Direct Injection Turbo (DIT) engines are built with 0.1016-0.8128mm (0.0040-0.032") clearance between the Camshaft Position (CMP) Sensor and the trigger wheel. At approximately 1.016mm (0.040") clearance, the sensor will fail to synchronize and result in a no run condition. Improper CMP clearance can be seen in the following five (5) symptoms:
ACTION:
Install a shim between the CMP sensor and the front engine cover. The shim will allow the correct clearance which should reduce the possibility of concerns. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
  1. [*]
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TH align=middle>PART NUMBER</TH><TH align=middle>PART NAME</TH></TR><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TD class=nobottomborder align=left>F5TZ-12K073-A</TD><TD class=nobottomborder align=left>Camshaft Position (CMP) Sensor</TD></TR><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TD class=noborder align=left>F7TZ -12J072-AA</TD><TD class=noborder align=left>Shim</TD></TR><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TD class=noborder align=left>F4TZ-6250-A</TD><TD class=noborder align=left>Camshaft Assembly</TD></TR></TBODY></TABLE>
OTHER APPLICABLE ARTICLES:
NONE
SUPERSEDES:
96-14-15
WARRANTY STATUS:
Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage And Emissions Warranty Coverage
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TH align=middle>OPERATION</TH><TH align=middle>DESCRIPTION</TH><TH align=middle>TIME</TH></TR><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TD class=nobottomborder align=left>970618A</TD><TD class=nobottomborder align=left>Install Shim And/Or Replace Camshaft Position (CMP) Sensor</TD><TD class=nobottomborder align=left>0.3 Hr.</TD></TR><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TD class=noborder align=left>970618B</TD><TD class=noborder align=left>Replace Camshaft - Econoline</TD><TD class=noborder align=left>15.4 Hrs.</TD></TR><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TD class=noborder align=left>970618C</TD><TD class=noborder align=left>Replace Camshaft - F-Series With Automatic Transmission</TD><TD class=noborder align=left>13.8 Hrs.</TD></TR><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TD class=noborder align=left>97061</TD><TD class=noborder align=left>Replace Camshaft - F-Series 4X4 With Manual Transmission</TD><TD class=noborder align=left>14.0 Hrs.</TD></TR><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TD class=noborder align=left>970618E</TD><TD class=noborder align=left>Replace Camshaft - F-Series 4X2 And Super Duty With Manual Transmission</TD><TD class=noborder align=left>12.8 Hrs.</TD></TR><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TD class=noborder align=left>970618F</TD><TD class=noborder align=left>Additional Time For A/C - Econoline</TD><TD class=noborder align=left>1.0 Hr.</TD></TR><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TD class=noborder align=left>970618G</TD><TD class=noborder align=left>Additional Time For A/C - F-Series</TD><TD class=noborder align=left>0.9 Hr.</TD></TR></TBODY></TABLE>
DEALER CODING
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TH align=middle>BASIC PART NO.</TH><TH align=middle>CONDITION CODE</TH></TR><TR style="FONT-SIZE: 10pt; FONT-FAMILY: arial"><TD class=nobottomborder align=middle>12K073</TD><TD class=nobottomborder align=middle>36</TD></TR></TBODY></TABLE>
OASIS CODES:
602300, 603000, 603300, 607000, 607400, 614000, 614500, 614600
Old Nov 5, 2005 | 10:26 AM
chapguy's Avatar
chapguy
What an awesome find! Thanks for posting this, I'm betting that the shim becomes a very popular item in here.
perryg114
Sep 30, 2010 05:18 PM
cheezit
Jun 24, 2010 07:16 PM
cheezit
6.4L Power Stroke Diesel
Jan 8, 2010 07:43 PM
Waldonian
2004 - 2008 F150
18
Oct 28, 2008 04:53 PM
ccerniglia
Oil & Lubrication
18
Oct 17, 2008 10:51 PM
