coolant temp sender
Old Nov 4, 2005 | 06:58 PM
heavyd86's Avatar
heavyd86
coolant temp sender
On my 94 explorer 4x4 how much antifreeze do I need to drain out to change the coolant temp sender? I also was wondering what I needed to do to get the air out of the system after the sender change? Thanks
Old Nov 5, 2005 | 02:48 PM
87 XLT's Avatar
87 XLT
Your Haynes manual will pobably tell you that if you quickly change the sender you wont lose enough coolant to worry about.
Make sure the engine is cold when you do it.
snowdog79
Jan 23, 2014 10:28 PM
trackenator
Mar 17, 2011 10:02 AM
borcht warrior
Mar 29, 2009 01:18 PM
Mercury Bluz
Sep 20, 2007 02:56 PM
